[quote=""Jeff V.""]
Like all stubborn problems, it can be solved with money. Or explosives, but we're not to that point. Yet
I think I have a plan...[/quote]
Does your plan involve a hammer?
For the ECU, no. For the hood, maybe
This popped up locally.
https://kansascity.craigslist.org/cto/d ... 98509.html
I ran the VIN through ASA. Says it's "Kensington Gray Metallic" ?
I think it'd be similar to this:
If I wasn't so far behind on my engine swap, I'd be half tempted to look into it and see if it's worth buying for the body.
Shit your this far in already. Do it.
You arent that far in really. If it means a solid shell to start with why not? Text the guy for pics?
I'm not going to waste his time. I've got too many spare parts as it is. I'll just keep going with what I have.
Asking for pictures is hardly wasting time. Thats like 2 min max.
"Tempted by the fruit of another..."
It's funny because my eventual plan is to paint the truck gray
Seriously, text the guy for pics already.
If you dont I will.
If you dont I will.
:suspect2:
EMS Почта России:
Track at official postal site
Date & time
Event/Location
Weight
Additional
21.05.2018 17:59
Accepted from sender
Вологда УКД 160990
0,055
Отправление Ems обыкновенное Без разряда Без отметки United States
21.05.2018 18:20
Arrived at sorting center
Вологда УКД 160990
0,055
United States Соединённые Штаты Америки 104000
21.05.2018 18:24
Обработка Уточнение адреса
Вологда УКД 160990
0,055
21.05.2018 18:25
Sorting
Вологда УКД 160990
0,055
EMS Почта России:
Date & time
Event/Location
Weight
Additional
21.05.2018 17:59
Вологда УКД 160990
0,055
21.05.2018 18:20
Вологда УКД 160990
0,055
21.05.2018 18:24
Вологда УКД 160990
0,055
21.05.2018 18:25
Sorting
Вологда УКД 160990
0,055
You got me a Russian mail order bride?
I love this sorta stuff. Jeff learns Russian or uses google translate like a boss to find a part nearly none of us could for cheap. Lol.
Mail order bride would also be bad ass but a different thread.
It's not nearly as much of a mystery as you think it is
Some programming cable or ecu?
MMCFlash. I was resisting buying it because I thought it was close to $350. Turns out it's come down quite a bit from that point. It also helps when you buy it direct from Russia rather than going through Hamish at EvoScan.
Is this the usb thing I saw in ecuflash while looking around? Is it actually a usb?
It's basically a physical security key to keep people from pirating the software.
You still edit the files with ECUFlash, and use the Tactrix hardware. This is just the actual reading and writing portion of the software that Tactrix couldn't bother to get working properly.
So you're jumping back into the programming side of the older Mitsu ECU's? I take its for the 2000-2004? Will it work on earlier ones like the 98-99?
