Tales (and pics) from the junkyard
Re: Tales (and pics) from the junkyard
[quote=""vr4""]Shit if i found a tt i would strip it clean[/quote]
We already have a spare engine, trans, transfer case, intercoolers and all the related plumbing. There's very little we don't have as far as useful parts go. 1G brakes and driveshaft won't do us any good. Having a spare rear subframe would be nice if I had gone through on my plans to rebuild and modify the one on my R/T, but that's no longer relevant. The steering rack would be kind of nice, but we don't need it.
The only reason I want the knuckles is because they'd be cheap, and they take up very little space. I could use them if I ever went through with the CTS-V brake swap.
- Jesters Deadd
[quote=""Gatecrasher""]We already have a spare engine, trans, transfer case, intercoolers and all the related plumbing. There's very little we don't have as far as useful parts go. 1G brakes and driveshaft won't do us any good. Having a spare rear subframe would be nice if I had gone through on my plans to rebuild and modify the one on my R/T, but that's no longer relevant. The steering rack would be kind of nice, but we don't need it.
The only reason I want the knuckles is because they'd be cheap, and they take up very little space. I could use them if I ever went through with the CTS-V brake swap.[/quote]
CTV brakes?!
CTV brakes?!
1999 Flashed Wide body 3000GT VR4, (Its Cianci's prototype car, but don't worry I fixed that.)
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
http://www.Chromedecu.org
How To Contact Me:
3SI: Jesters Deadd
Ive found two TT's in the yard. The first one some latinos grabbed the motor in front of me. The second time i had a virgin 91 that i had my fill with.
[quote=""Jesters Deadd""]CTV brakes?![/quote]
They should fit too. But I think you'd need bigger wheels. like 19's possibly
Spyder has 19s :suspect2:
Whatever happened with your Evo setup?
- green-lantern
[quote=""aaronatstate""]They should fit too. But I think you'd need bigger wheels. like 19's possibly[/quote]
I think those are usually mounted behind 20's right?
[quote=""Gatecrasher""]Spyder has 19s :suspect2:
Whatever happened with your Evo setup?[/quote]
Have not been able to find the time to put them on!!! Tentative to put them on this weekend. All the machining is done, just gotta get the time to drill the holes to mount them!
[quote=""green-lantern""]I think those are usually mounted behind 20's right?[/quote]
CTS-V has 19's.
CTS-V has 19's.
- green-lantern
CTS-V has 19's.[/quote]
Oh, I thought they were 20's
- Jesters Deadd
So I was at the yard this weekend and found a 3s that had gotten there just a couple days ago. it was a 95 SL. Well the whole engine top end had been taken apart and sorted in labled baggies in the trunk! it was neat. THen sorting through that stuff I found a great set of Taylor Made Plug Wires, like $98 new! Then I found the stock shifter. So I check and sure enough he has a $120 3sx short throw shifter installed. THen I was about to leave so I check the passenger side seat and in the floorboard is a set of 3sx solid engine mounts that look brand new. Scored it all plus the ptu $60.
How To Contact Me:
3SI: Jesters Deadd
How To Contact Me:
3SI: Jesters Deadd
Nice finds. I was happy to snag a 3sx pulley for 9 bucks sunday off of an SL. Saw these the other day...
First time i had ever seen this.
Jeff i noticed this one and thought of you. Looked like a normal DOHC case. Number engraved in the case is 7784.
This is where it gets weird. He managed to retrace the circuits on the board. You can see it in the middle of the pic. Also has new caps too. What circuits was he attempting to circumvent?
I'm overdue for a visit. I don't really need anything though. It'll take something special to pry my wallet open now. The black dash from the 97 GT is the last non-critical thing I even thought about buying.
Those transistor clusters drive things like the ISC if I remember correctly.This is where it gets weird. He managed to retrace the circuits on the board. You can see it in the middle of the pic. Also has new caps too. What circuits was he attempting to circumvent?
Interesting. Wonder if the leaky caps caused that or if he was trying to alter it.
I've been meaning to post these.
Pretty sure this BMW went swimming.
I doubt any of you can top this.
Most of the interior was stripped bare, but the hydraulic cylinder and most of the antenna mast was still intact. It was pretty cool.
Probably repairing the fried circuits after a shorted isc motor took them out.
- green-lantern
[quote=""Jeff V.""]I've been meaning to post these.
Most of the interior was stripped bare, but the hydraulic cylinder and most of the antenna mast was still intact. It was pretty cool.[/quote]
Vera, stop him before he brings home another tornado victim
- Jesters Deadd
[quote=""ChargerX3""]Nice finds. I was happy to snag a 3sx pulley for 9 bucks sunday off of an SL. Saw these the other day...
HAha, now that you mention it that SL had a 3SX aluminum pulley too. Did't grab it though.
[/quote]HAha, now that you mention it that SL had a 3SX aluminum pulley too. Did't grab it though.
How To Contact Me:
3SI: Jesters Deadd
How To Contact Me:
3SI: Jesters Deadd
Man I wish I could find a modified 3s lying around. He's I've seen is one with air bags and the sl.
We're long overdue for an update here.
3000GT, with bullet holes.
The mirror may have been shot off, as well as the rear quarter window, side window, and hatch glass. There was a sticker on the windshield that said "hold for inspector". No signs of blood, but I didn't exactly look very hard.
