progress pictures.
Re: progress pictures.
When it got timed and turned it over....i was so happy. Those timing marks are dead on too and it turned over so nice. I still have some bridges to cross before I am all in the clear, but it shouldnt be a whole lot longer.
[quote=""My92Stealth""]In addition, I know nothing of your planned setup.
Lay it on me homie![/quote]
I think this is a full list. forged crank, wiseco pistons, emanage blue, spec stage V clutch, external fuel pump, e16g's, adapter plates w/open dumps, solid motor mounts, rays rods, Rays head lift fix, billet aluminum timing belt tensioner, Quadco shaft, quadco spool, denso 660, AEM WB02, cinci 3 A pillar pod, leatherseats.com, vac reduction, maft, Nitrous,window switch, FIAV block off, FMIC, custom IC pipes, Custom exhaust.
I am sure I am missing some and i think i will have enough money after xmas to buy a ss tcase.
GTO Assassin
Post by GTO Assassin »
You mean one of these?
:icon23:
Scotty
yes money bags, one of those.
GTO Assassin
And lets not forget one of these bad boys either....
yes hopefully i will have enough to get that one as well. Now go drive your car before i get pissed.
GTO Assassin
:lol: My bad Coop. It's funny on two counts. You want what I have, and I can't even run what I have. Wait, that's not funny. It's more stupid and I'm a tool. :sulk:
Scotty
go get your car dyno tuned, the rings have broken in by now. I hope you make like 420whp ;)
GTO Assassin
:rofl: :suspect2:
what grade of roo piss you all have over there any ways?
GTO Assassin
Fuel? 98 RON.
We also have a 101 RON fuel at some servo's. (service stations)
Scotty
wtf is RON?
[quote=""DCIV""]wtf is RON?
a method of calculating octane. the US uses rm/2 method i believe, which is usually lower than RON. i may be wrong though
[quote=""tabasco122""]a method of calculating octane. the US uses rm/2 method i believe, which is usually lower than RON. i may be wrong though[/quote]
You're right.
[quote=""aaronatstate""]You're right.[/quote]
:goldstar:
thats from me for me...
GTO Assassin
Research Octane Number (RON)
is measured under mild conditions and is more important in controlling part throttle knock.
so scotty is runnign around with race gas always?
[quote=""DCIV""]so scotty is runnign around with race gas always?
98 RON is basically equivalent to 93 here in the US coop.
damn fucked up down there, always have to be diff.
Tujin
Post by Tujin »
spec stage V?
>>>>>Image<<<<<
