Lexus nx 200t
Re: Lexus nx 200t
DCIV wrote: ↑Mon Apr 01, 2024 9:47 pm
ChargerX3 wrote: ↑Mon Apr 01, 2024 9:44 pm Yea, i wouldnt trust NY vehicles.
It looked clean under it. I had them put it on a lift. I believe it was either well taken care of or just Honda is better at rust prevention.
Unless you put it up under a lift I would still steer clear. Also all those pot holes jack up suspension and other components. Not to mention people are sneaky AF there. Nope.
Re: Lexus nx 200t
This thing drives great, from Knoxville, and is a very good car. I do wish it was bigger and a diff color but it’s okay.
Re: Lexus nx 200t
Got my first “luxury” car tax.
Service calls for new plugs every 40k. Odd enough. Whatever, it’s simple just do it.
Go to Toyota. They can’t even order the plugs. What?! Also they are 41 bucks a piece. 41!!!!! What in the Lexus bong they smoking.
Re: Lexus nx 200t
Can get NGK Laser Iridium for under $14 a piece from rockauto
Re: Lexus nx 200t
Advance has those for 12. I havnt looked up what factory plugs actually are, is that what they use?
Re: Lexus nx 200t
Just get Iridiums and be done. It's a daily driver, and they will be way overkill. Chances are they didn't use iridium stock if they are saying 40k spark plug changes.
Re: Lexus nx 200t
Yeah just make sure you get the NGK or Denso plugs as those are probably what Toyota... err Lexus used as originals
Re: Lexus nx 200t
You have an 8AR-FTS with with VVT-iW (Variable Valve Timing - intelligent Wide), ETCS-i (Electronic Throttle Control System - intelligent), and ESTEC D-4ST (Economy with Superior Thermal Efficient Combustion Direct injection 4-stroke with Turbo).
https://en.wikipedia.org/wiki/Toyota_AR_engine#8AR-FTS
I love Japan. :lol:
Re: Lexus nx 200t
All the acronyms, all of them!
Re: Lexus nx 200t
Washed (as in with my clothes) my Lexus key. Fail. It’s still working and I opened it up and dried it out for a day. But I expect it to quit.
Re: Lexus nx 200t
Oooof!
Re: Lexus nx 200t
Get it in a bowl of rice.
It's probably going to cost you a couple hundred to get a new one made at the dealership.
Whatever happens, keep this one anyway. Even if all the remote functions die, it should probably still work as an emergency key if you put it in the dead battery pocket.
Re: Lexus nx 200t
I did the same thing with one of my ST fobs. I didn't let it dry completely, that was a mistake. Had to get a new one at the dealer. And of course have it programmed there too, because you need 2 keys to program a key yourself :lol:
Re: Lexus nx 200t
aaronatstate wrote: ↑Mon May 13, 2024 5:26 pm I did the same thing with one of my ST fobs. I didn't let it dry completely, that was a mistake. Had to get a new one at the dealer. And of course have it programmed there too, because you need 2 keys to program a key yourself :lol:
I have a spare key so I will not be out. Work guy that owns local AAA said it would cost me (him) about 150 for another. So I bet about 300 if I was off the street.
Re: Lexus nx 200t
Went out to pack the car to take the oldest to piano lessons. Saw a tire low….3.5psi in it. Thought that’s odd, the low tire wasn’t on but during brg the wife was gonna take the Lexus and the rear tire light was on but it was 28.5psi. So I thought maybe I just missed it. Filled it up. Went inside to get some stuff. Came back out and could hear it leaking out!!! So avalanche had to get unhooked and I will have to take the tire off tonight. Have a packed day.
Re: Lexus nx 200t
Lost the lug nut key. I’ve kept the vr4 one for 20yrs. Somehow I lose the Lexus in a couple months!!!! No place around town has it. I found a Facebook part out that does. Hopefully I didn’t get screwed out of money.
Re: Lexus nx 200t
Just buy one of the harbor freight removal tools and 4 more regular lugs
Re: Lexus nx 200t
DCIV wrote: ↑Tue Jul 30, 2024 4:05 pm Lost the lug nut key. I’ve kept the vr4 one for 20yrs. Somehow I lose the Lexus in a couple months!!!! No place around town has it. I found a Facebook part out that does. Hopefully I didn’t get screwed out of money.
locking lug nut key? you know theres like 25 different patterns right?
Re: Lexus nx 200t
You can also get a hold of the company that made them, and if you prove it's your car they'll let you buy a replacement.
Re: Lexus nx 200t
Chris GTO TT wrote: ↑Tue Jul 30, 2024 4:10 pm Just buy one of the harbor freight removal tools and 4 more regular lugs
I have one of those. That thought did cross my mind.
