Stereo
Re: Stereo
Anyone looked for double din bezel recently?
Re: Stereo
So because Of the size of this thing, I need to make a custom mounting bracket. I was just thinking a U design with the ability to slide forward and backwards with a long cut, tighten to desired depth with nuts. Then a hole in the middle that I can go left or right to line up things perfectly.
Already made my cardboard templet, gonna get some aluminum at lowes when I get a chance and make this happen.
Re: Stereo
The adapter I bought off Walmart online didnt fit. Had to order another one.
Re: Stereo
Finally found a double din cover. Bought it. Guy sends me one that has two slots instead of one. Grrrrr.
Re: Stereo
You need to cut the bar out.
Re: Stereo
Some kits are like that.
Re: Stereo
[quote=""tabasco122""]You need to cut the bar out.[/quote]
That would look like crap when there is one out there. Even then I may have to. I messaged him and he said he thought he did send the right one. I showed him a pic and he said he would look when he gets home. I bet its gone.
Re: Stereo
The kit we carried at best buy needed to be cut.
Re: Stereo
Can't just order one from the Mitsu dealer?
Re: Stereo
[quote=""mjannusch""]Can't just order one from the Mitsu dealer?[/quote]
Look into this. I'm sure it's not much.
I may have one lying around somewhere...
Re: Stereo
Shit. I will, I just figured if it was this hard to find they didnt have one.
Re: Stereo
92 stereo diagrams. We confirmed his car never had an amp based on the VIN and ASA.
http://xtreme3s.net/Coop/92VR4Radio-1.JPG
http://xtreme3s.net/Coop/92VR4Radio-2.JPG
http://xtreme3s.net/Coop/92VR4Radio-3.JPG
Re: Stereo
These are still complicated for me to read. Im gonna try and figure them out but Im basically going off of wire color on what to connect to what.
Thank you very much btw.
Re: Stereo
Eh, you've got my number. Let me know if you need help. As long as you get power and ground right, the rest can be done with trial and error. Take a few minutes to learn the color codes on the wires and that'll help a lot. Most of them are pretty obvious.
B = black
BR = brown
G = green
GR = gray
L = blue
LG = light green
O = orange
P = pink
R = red
SB = sky blue
V = violet
W = white
Y = yellow
So if a wire is labeled R-Y on the diagram, it'll be red with a yellow stripe.
B = black
BR = brown
G = green
GR = gray
L = blue
LG = light green
O = orange
P = pink
R = red
SB = sky blue
V = violet
W = white
Y = yellow
Re: Stereo
https://www.installdr.com/Harnesses/Mit ... Wiring.pdf
I think this will help me.
Im gonna do it while I sit at work tomorrow and hopefully when I get home and plug it in and it works.
Yeah right.
Yeah right.
Re: Stereo
are you missing the radio plugs in your car?
Re: Stereo
For my car, I was gonna do it away from the car.
Re: Stereo
Buy a wiring harness and connect the colors lol. It's not rocket science.
Re: Stereo
I bought the harness, are the colors the same? Hadnt looked at one and never done an instal.
Re: Stereo
They are not the same color.
