So... whats in the works?
GTO Assassin
Re: So... whats in the works?
What brand are they Brian? Not JIC?
Scotty
Scotty
I'm just trying to keep my car running. hah
[quote=""GTO Assassin""]What brand are they Brian? Not JIC?
Scotty[/quote]
Judging by the sticker on them, I'm going to take a guess and say Megan Racing
Scotty[/quote]
First to 184 million
Thats correct.
Hans, once I get all this shit together and maybe, possibly get a nitrous set up I wanna come out and see what kinda powa the SOHC is making.
Seriously, I am curious being I do have one of, if not the, fastest NA SOHC known.
I finally got my car running last weekend after 4 1/2 months of sitting (combination of waiting on parts and finding time to work on it). But.....new clutch/pp, turbos, OS/spool, and a whole bunch of other little things that got replaced along the way.
It ran for about 2 days and then I found a coolant leak coming from one of the lines on the rear turbo. So it's in pieces again. Also, my crank pulley is wobbling a little, so I need to take that off and see what's going on.
I can't for another 2 weeks though cause of the stupid nose surgery. All I want to do is drive my car!
I just finished Richard's VR-4 thats been plauging me this past week+.
On my Conquest I've got some things to do.
-replace door hinges I just got in mail
-fab new wastegate bracketry
-fuel pump hotwire, hook up knock sensor warning light (my 89), get boost where I want it
and I was about to start a paint job on it.
When I can I'd like to upgrade to MPI, megasquirt, new FMIC & piping, Mustang 5.0 TB, etc.
-'79 Yamaha XS11 special, custom work in progress
-'93 Stealthubishi
-'93 Stealthubishi
- My92Stealth
I finished my 15g install a few weeks ago. I just installed my 550ccs and Walbro, along with my safc last weekend. I got a general base tune down today, and someone is coming over to fine tune this coming week. Ill be taking it to the track on friday hopefully. Then week after next (maybe), Ill be replacing the stock clutch.
[11:44] BobaF344: its just guy love between two guys
[11:45] IR Dianna: You're both gay.
[11:45] BobaF344: ROFL
- moffman93'
just replaced my interior door panels with ones in better condition.
Waiting for new AC hardline so i can have AC again.
Just got a new PS bracket so i can enjoy powersteering again in the near future lol.
waiting on a turbo timer to be installed.
Just bought some mint 94 glass headlights so i can begin my 2nd gen front end conversion in a few weeks.
If you need any help with the wiring let me know. I am the one who took the time to fiugre it out and made the diagram for the light conversion. I also plan on swapping headlight buckets in the next few weeks since my passenger one was cruxhed at one time and my hood doesnt line up exactly right. I will take pics and document there too. I already actually did document a 2g conversion once when I did it to a 92 RT but that was several years ago with a shitty camera, time for an updated version.
3SX SS Brake Lines(red)
3SX SS Clutch Line(red)
AAM Dual Intake/Velocity Stack System
AEM Twin-Fire Ignition
Aeromotive Adjustable Fuel Pressure Regulator
Blitz Dual Stage Boost Controller Spec R
Brembo Cross Drilled & Slotted Brake Rotors
Cusco Rear Strut Bar
Dejon Powerhouse Intake Pipes
Denso IK-27 Iridium Spark Plugs
Earls fittings & hoses
Eibach Pro-Kit Lowering Springs
EK2 Exo-Cage Transfercase Bracket
EK2 Billet Big Bore Fuel Rails
Enkei Bortex RPM2 18x9
ET Performance Krank Vents
Falken Aziens ST115 265/35/18
Flex-A-Lite Twin 12" 2500 CFM Fans
Full Throttle Speed & Style Scan Master 3
Greddy Radiator Cap (1.3Bar)
Greddy Oil Fill Cap
Greddy P/H/W Silver EGT
Greddy P/H/W Silver Oil Pressure
Greddy P/H/W Silver Coolant Temp
Greddy E-Manage Ultimate(Speed Density Mode)
Greddy Type RS BOV
GTPro Front Mount Intercooler
HKS Super Drager Cat Back(3.75")
HKS Turbo Timer(black)
IPS Motorsports TD05 Turbo Kit
IPS Motorsports Stainless braided Turbo Oil Feeds, Returns
IPS Motorsports 272 Camshafts
IPS Motorsports Titainium Valve Springs
IPS Motorsports Titainium Valve Spring Retainers
K&N Twin Air Filters
Kormex Hardened Output Shaft
Kormex Hardened TCase Input Spool
Koyo Aluminum Racing Radiator
Maximal Performance Solid Motor Mounts
Maximal Performance Rear Control Arms
Maximal Performance Koyo Radiator Brackets
Mitsubishi Big Bore Lifters
Mitsubishi TD05H EvoIII Big 16G Turbochargers
Optima Red Top Battery
PLX Devices SM-AFR Wideband Controller
Precision Turbo & Engine 780CC Fuel Injectors
Power Enterprises Kevlar Timing Belt
RPS Carbon/Carbon Twin Disk Clutch & Chromoly Flywheel
SX Fuel filter
Walbro 255lph Twin Fuel Pumps
Custom Stainless Downpipe/Testpipe
Custom Short Shifter
Custom Stainless Braided Oil Cooler Lines
Custom In-Tank Twin Pump Fuel System
Custom Denso Coil-On-Plug Ignition System
Custom TD05 Turbo Coolant feed & returns
Custom Crank Scrapers
=== Style ===
1999 front end
1999 sail panels
1999 rear bumper
1999 side skirts
GTO Side Markers
GTO Tail lights
GTO Garnish/Badges
GTO Rain Gutters
GTO Rear QTR Windows
Not a whole lot yanno, just some little stuff
Greddy Oil Fill Cap
Greddy Type RS BOV
SX Fuel filter
=== Style ===
1999 front end
1999 sail panels
1999 rear bumper
1999 side skirts
GTO Side Markers
GTO Tail lights
GTO Garnish/Badges
GTO Rain Gutters
well this is my detailed To Do list
-3sx braided clutch line
-rps max street clutch
-new mitsu flywheel
-defi bf oil pressure
-defi bf boost
-defi bf oil temp
-defi bf water temp
-prosport fuel pressure
-aem wideband
-shortblock of some short
-99 lifters with new vss
-msd coils
-msd 8.5mm wires with ngks
-td04 15gs?
-cianci fiberglass pillar
-intrax springs
-99 front end
-solid shifter bushings
-all my polished/powdercoated crap
-fp gauge with honda fpr adapter
-fuel rail loop
-evo injectors?
-maximal solid motor mounts
-flexalite fans
-koyo radiator with maximal mounts
-99 headlights and corners
-ss pre turbo pipes
-ultimate performance front strut bar
and stuff that im sure im forgetting since my basement is like a garage right now
-new mitsu flywheel
-defi bf boost
-defi bf oil temp
-defi bf water temp
-aem wideband
-msd coils
-td04 15gs?
-intrax springs
-99 front end
-fuel rail loop
-evo injectors?
-flexalite fans
-ss pre turbo pipes
- Monochrome
- Founding Members
My car is completely stock and will always stay that way.
except4thedr800s
GTO Assassin
[quote=""Hans_GZP""]Judging by the sticker on them, I'm going to take a guess and say Megan Racing
That says Megan?
I can't even read that.
Scotty
That says Megan?
Scotty
[quote=""stealthee""]Thats correct.
Seriously, I am curious being I do have one of, if not the, fastest NA SOHC known.[/quote]
I'll give you a run for your money in my 97 base haha. We'll have a SOHC dyno shootout
[quote=""EricVR4""]I finally got my car running last weekend after 4 1/2 months of sitting (combination of waiting on parts and finding time to work on it). But.....new clutch/pp, turbos, OS/spool, and a whole bunch of other little things that got replaced along the way.
If your crank is all tight, the harmonic balancer part of the crank pulley might be coming apart. Get that fixed ASAP if that is the problem.
My C5 has been running perfectly since I bought it. I now have complete confidence in its reliability, and would not hesitate to drive it cross-country.
I take it every month on my trips to Gainesville (200 miles each way), and absolutely love it as a highway car. It's fairly quiet, smooth, and has awesome passing power anytime I want it, even in 6th gear. The Heads Up Display I recently installed has made it easier to speed (because I never have to look down at my instruments), so I don't know if that's a good thing or not. Also, I can count on 28 MPG every time.
I was cruising at 95 MPH the other day and decided to check my "Instant MPG" readout. It was 26 MPG
People also tend to get out of the way quickly when they see a yellow vette in their rear-view mirror.
I recommend these cars.
The car right now is almost completely gutted and getting ready for some flat black paint in the engine bay and interior.
But the plan for now is to get DR's 2871R kit + supporting mods with an AEM to control it all and rebuild the engine to be able to handle the power (spun bearing). Don't think I'll be getting to many new parts though until next year after I know where I'm going to be living.
"The early bird gets the worm, but the second mouse gets the cheese."
"The greatest deception men suffer is from their own opinions."
GTO Assassin
Aaron - how often do you beat on her?
Scotty
Scotty
