Post your car's "To-Do" list!! Come on.. we've all got em!!
Zentelis
Re: Post your car's "To-Do" list!! Come on.. we've all got em!!
Post by Zentelis »
I'm all the way to the half shafts now. The alternator is out, all the wiring/hoses are out of the way, the AC is disconnected..and holy crap am I in for it.
A couple years ago, my oil cooler blew a line while I was driving. I didn't know this until I got home and there was no oil in the car (how i didn't spin a bearing, i'll never know).
Well..I just found out where most of that oil went...all over the lower driver's side engine bay. _Everything_ is caked in sludge.
I plan on dunking the engine in simple green :p
If I rented a portable steam-cleaner, could I safely use that on parts like the AC compressor, etc?
Either way, I'm going to have a river of sludge washing out of my garage by the time I'm done cleaning this monster.
Oh, I also found out why my engine bucked around so much. The rear engine mount bolt sheared off :p I went to loosen the AC tensioner pulley and noticed that the entire engine shifted when I applied pressure to the ratchet..I thought "even with bad motor mounts, it shouldn't be THAT easy to move".
So I looked and sure enough..no bolt.
I'm also thinking of ruining my budget and replacing the front bumper and all the under-side covers..almost every plastic piece underneath is ripped, broken, bent, or warped.
GTO Assassin
Post by GTO Assassin »
How bout a "Getting Done" list.....
Full engine rebuild
Stage 3 heads
Software upgrade on Haltech Stand alone ecu
GT2871R's
Custom manifolds/DP/Dump Pipes/Cold Air Box
New engine bay plumbing for FMIC (due to bigger turbo's)
My "To Do" list would consist of;
18 spline to 25 spline conversion
SS Tcase + Midcase (in garage waiting on above)
CF Hood
Clutch
I think that will do me for now! :)
Scotty
New list for new car (In order).
*Drive car home from AZ
*Subscribe to Sirus Satellite Radio
*swap non-tinted door windows from RT to VR4 sos to pass inspection
*Install gauges
*Install DSBC
*Install tein coilovers
*Purchase & install adjustable rear control arms from Terry
*Purchase & install 94/95 engine wireharness
*Install 94 TT ECU
*Install non-abs lines and proportioning valve
*Install AWS delete arms & purchase plugs to cap the rear PS lines & differential
*Locate & purchase black leather interior out of a 96+ 3/S
*Save $$ for a set of polished Volk GTCs w/ BFG GR tires
EricVR4
Post by EricVR4 »
Haha, nice!
I think after work today I might attempt to fix the coolant leak at the rear turbo and figure out why my crank pulley is wobbling a little. After that the car should finally be back on the road....after 5 months.
EricVR4
Post by EricVR4 »
Haha, yeah. Stupid little things. I'm hoping the wobbling pulley doesn't turn out to be anything too bad. The bolt seemed tight, which has me kinda worried.
The coolant leak has me really pissed off though. I can't seem to get it. I've checked both lines going to the rear (from the tstat all the way to the turbos) and they're dry. I've replaced all 4 copper washers again with new ones, and it still leaks from the rear. It's a fairly slow leak and only starts once the car's hot and has been driving for about 10 minutes. But it drips straight down onto the oil return line and runs off that onto the ground. I'm going to replace the washers again today and see if it finally stops. Doesn't make sense though.
EricVR4
Post by EricVR4 »
Yeah, everythings as tight as I can get it (without feeling like I'm going to start stripping it). Doesn't make any sense, because those washers make good seals, so I don't understand how it could be leaking.
I have the plenum and all that off right now anyway cause I was checking all the lines running near the tstat. But without the heat shields there anymore, it's not too bad. I replaced the washers the first time with everything still there, minus the IC pipe.
EricVR4
Post by EricVR4 »
The stock Mitsubishi ones. I ordered a couple packs of them just in case.
EricVR4
Post by EricVR4 »
Yeah, who knows. We'll see how it goes today :p
moffman93'
Post by moffman93' »
fix my powersteering belt(it just wont go on haha) seriously it doesnt fit...
- Install turbo timer
- install AC hardline
- get a new wheel(bent)
Nazarah
Post by Nazarah »
I'm getting in a bit late on this one, but I'll throw on my to do list:
check for boost leaks
install Blitz turbo timer
install TurboXS MBC
Gut cats
new power antenna
fix what ever the hell is wrong with my window on the drivers side that makes it too tall and hits the molding when I try to shut my door and it does not shut all the way.
TajMan
Post by TajMan »
Conquest:
-looking for AC hardline now
-New radiator
-new eBay FMIC
-stock intake manifold converted to MPI, Mustang 5.0TB
-new intake piping for everything
-megasquirt for fuel management
-upgraded fuel pump
-660cc injectors
-A slew of new gauges, wideband 02, electronic boost controller
-rebuild tranny later later, short throw shifter, new driveshaft or something to reduce drivetrain backlash
-new front seats from Checker $250
-steering wheel, shift knob, pedals, etc
-new brakes
-new speakers, sub
-hood scoop, finish paint job (doing that now)
-tint windows, get rear window louvers
Ahhhhhh, I've done SO much already!
-'79 Yamaha XS11 special, custom work in progress
-'93 Stealthubishi
