[quote=""green-lantern""]Not going to tell me about the engine build?
Where you going? Texas?[/quote]
North Carolina
Engine build:
Flyin Miata II turbo kit (comes with hydra stand alone ECU, sensors, turbo, manifolds, down pipe, lines and FMIC)
"Tune up" kit (all new belts, pullies, spark plugs, water pump, thermostat...)
All new engine and trans seals
FM Happy Meal (what they call their clutch/flywheel)
New master/slave for the clutch
New master for the brake
Large rubber shift boot
New chassy bolts
"Little" Big brake kit (all 4 willwood calipers, lines, adjustable prop valve...)
VMax extreme sport kit (adjustable coilovers and roll bars)
New alternator and starter
Energy suspension bushings for the whole chassy
"Hard rubber" motor mounts
New lower ball joints
Exocet specific fuel system
Special tools needed for installing seals
